GRX 820 x1 Mech with 11-36 cassette
Sorry not yet. It’s still on my to-do list though
Did you try this in the end? I just got a crux with grx and have been considering the same thing
I have a Specialized Crux with that same set up. In order to run it with my zipp303s (which are not compatible with Microspline) I run it with a HG 11-36 12-speed shimano cassette. It works excellent! You migth need to check your chain length, and you need to adjust the b-screw. That is it.
Wondering if this is still working for you? I’m about to pull the trigger on a crux that’ll be used for 80% road but the complete lack of info on using an out of spec 11-36 cassette has me a bit worried.
These 1x specific rear derailleurs with flat parallelograms and large top pulley offsets track the cassettes by the difference in chain wrap. Shift to a cog 3 teeth bigger and the top pulley rotates the right amount to clear it. It doesn’t matter where in your cassette the 36 is.
