Distance and speed calculated incorrectly
I wonder if people using Zwift complain about the speed being too quick!?
With my old Muin direct drive trainer there was a magnet in the freewheel. You just needed to have sensor to pick it up, I had a Bontrager one​:+1: and remember the fly wheel isn’t a 700c wheel, or else it’ll pick you up doing 17mph when you are sprinting to the max :joy:
Some people do, but most seem to ignore it. It is at least a bit more “accurate” since it is based on the rider weight and height, along with the calculations on the roads and surfaces within Simulation mode. And in ERG mode, the speed and distance are similar since it is still “power” based applied to the same calculations. That is all different than the pure wheel RPM x tire circumference that we get in TR.
Even more so when drafting in a race :joy:
Do you ride the same routes in the same conditions? If not then even your outdoor rides may not compare. I’ve done flat group rides at 200W and >40kph, I’ve done solo hilly rides at 250W and <30kph, and I’ve done offroad rides at <20kph. Only meaningful way to compare and track them all is with power and TSS, or at least estimated TSS based on HR and time. Speed and distance is just too variable.
“Technically” TR is calculating speed and distance incorrectly because when you ride inside you don’t have any speed nor are you traveling any distance. But they are also calculating both of those things correctly based on the information that they are getting. Either you have a speedometer on your rear wheel or your trainer has it built in and is transmitting the speed of your rear wheel to TR and that is how they are getting your speed and distance. They aren’t doing anything to account for power, weight, aero, etc.
While I agree that some people may like to have a more sophisticated speed/distance measurement, I think it also opens a whole other can of worms. Living in a flat area, I might complain that my 240W rides has an 18mph avg and not the 20mph that I want, while a rider in a hilly/windy area might complain that 18mph is too fast and it should be 16mph like they do in the mountains. Then if you give people the ability to customize their own model you get into people asking what their true CDA is and then having people here on the forum giving unprofessional and uniformed estimates.
It’s just easier to say “we don’t provide that calculation unless you give us speed data. In which case we just report what you tell us”.
If you are just using it for tracking purposes then you could go into strava or TR or wherever and add a manual entry of 0 minutes but with the distance that you think bridges the gap between whatever TR is reporting and what you think it should be. Of course this would only work if TR is under reporting and not over.
Yup, the only time I really look at distance to track things is when I look at previous years and say “wow I rode 8,000 miles this year and I only rode 6,000 last year. That’s a lot more riding that I did!” And it probably does indicate that I did a lot more volume but I’m not using it for a week over week comparison of training.
My only frustration with this is that something, I believe the TR app but I’m not positive, resets my Kickr Core from ‘speed sim based on power’ from on to off. I can go in and set that to on, but within a ride or two it resets it back to off. No clue why
Frustration is less about the ‘distance’ being correct or incorrect and more about something changing settings on my trainer that I didn’t change myself
I did try that the 0 wheel circumference after the last discussion, it does report zero distance about 30% of the time. I’m often doing zwift at the same time so just upload that ride to Strava. Starting to lean towards the who cares camp though. So no worries!
All correct but still why not to make more closer to something like a flat road ride instead of some number based on freewheel rotations, shouldn’t be that difficult
Yearly mileage I look but also weekly. I like mentally to be above 200km closer to 300km. But the with 6h on TrainerRoad I get little more than 100km :frowning_face:
I will try that :+1:
