Should also point out my last bike fit was a retul bike fit (i.e. ir emiters stuck to me) on a guru fit bike. They kept the wattage very low as they didn’t want me to sweat and cause the ir emitters to shift and the retul system made me pedal slower then my regular cadence as it couldn’t measure well at a faster speed
Less than ideal, IMO. Just leaves the door open for differences in the functional fit outside.
Fitting with the rider using at least their most common power level effort is a good place to start, unless they have specific focus at other data points. I can tell you that a great fit at one power level is not guaranteed to feel the same at other levels.
My own fit is centered around Tempo and above. When I do recovery level rides, I have to take some extra steps to prevent issues from comfort to even avoiding saddle sores from the difference in loading on the saddle relative to the force in the pedals. It’s a real difference, at least for me.
Bikes have always been designed at “pro” geometry and then sold to the general public. If anything we have way more options these days and have the ability to get a bike to be fit to you more personally.
I don’t think any fitter in the world could make this comfortable with the 1990 tech available (just look at the reach):
Vs all the options and ability to fit today’s race bikes:
I agree with that, the slow rides are usually the most uncomfortable
Don’t let the difference in components and frame design (mostly dropped top tube angle) fool you.
This is NOT conclusive, but I over-layed the two bikes and set them to scale with identical 990mm wheelbase.
Note the drop is less on the new bike, despite what looks bigger from the illusion of the seat post.
The only point here is that real measurements matter most, pictures can be misleading.
I thought the trend in smaller frames was relatively new. Now bikes are set up to optimize aerodynamics on the hoods with straight forearms so they need a bigger drop. Looking at pictures of tour riders in the early 00s and 90s, their fits don’t look that different than what mine is. I could be wrong though.
His saddle is too low ![]()
Want three different opinions? Ask three different bike fitters.
Hump, I have seen you on a bike (usually while hanging on to your wheel), and you always looked good to me.
I used to get paid to do bike fits in shops, and got trained by an unnamed fitter whose philosophy I no longer believe in. Some pros look terrible on their bikes. Some pros look elegant. They’re all riding in positions that allow them to get the miles in, but, some of those positions also put their bodies in positions where they need a lot of minor upkeep on the massage table, but they don’t want to change them much.
The best “fitter” is the one who could ride with you a few times over the season, see what you look like under pressure, get to know your body’s habits and niggles. I don’t think that a single session, even with motion sensors, can do this.
All “fits” are starting points. After that, it’s the rider’s body and the bike. One is somewhat adaptable. The other is somewhat adjustable. Like many other things involving the bike-y, there is no secret sauce or magic bullet.
Compared to my SL7 Comp, that photo has all the spacers removed.
Yup, the web pics are usually full drop on the stack with 1 or no spacers (and a cut steer tube, even if Photochopped).
Delivered bikes will have about 20-30mm of spacers installed and the related longer steerer. All part of giving the maximum material condition since removal is easier than adding back ![]()
Bikes in the 80 / 90s were comfortable. But then when you are relatively young, anything is pretty much comfortable
Except as Chad demonstrated above, that is not necessarily true.
I know that is the popular thinking, but it doesn’t necessarily hold up.
Another element that is not factored into the equation is the design for HB and the transition from shifters to the bar. Look at the bar shape on the Lemond bike above…my wrists hurt just thinking about riding the hoods.
Yup, those old setups look like torture devices to me. I still remember with mixed fondness, my old Colnago that was my first road bike in 1997. 7-speed Mavic with DT shifters and the bar and hood setup was “traditional” for that mid 90’s era, but so so bad. That and the Sella Italia Flite that I lusted after as a kid turned out to be a torture device of a saddle for me.
This bike happened into my life the same time I worked with the owner of Fit Kit Systems (1997 until he sold it in the mid to late 2000’s?). That bike, coupled with what I learned from the owner then were my entry to fitting. Considering what we had then to what we have now, there are some MAJOR differences in bike setup that leads to notable changes in joint angles and related comfort.
Then consider how much we have learned with the advent of things like wind tunnels and comparing today’s fits to what was done 20-30 years ago are partly laughable. It’s like saying the same thing with respect to training and fitness. We are light years ahead on training, and fitting has followed suit to some degree.
Talking with the pro fitters when I was at the Specialized wind tunnel lead to some interesting takes on “pro” fits and what is actually fast. Conventional wisdom can work, but is far from perfect. The guys there had great stories about changing to higher and wider fits, with improved aero and power results compared to the “pro” style fits that riders had previously adopted. All that to say that we know a LOT more now than what was considered the best/fastest fitting back in the day.
The old bikes they spent more time on the drops and the tops, the hoods were small, so not much time spent there.
Hump
Cinelli 66 bars!
This is a bit of bro science, but I’m seeing slightly faster (solo) speeds on the hoods of my Tarmac.
Not as comfortable as my previous bike, but no real issues on 3-5 hour rides.
Never heard of “pro vs amateur” fits.
I’d think the aim of your bike riding plays a big role, as does your age. When you’re 20, and your sole aim is to win bike races, you can put up with a lot more discomfort than when you’re 50 and your sole aim is to visit as many cafes as you can in a ride.
Also when you’re young, you likely don’t have many of those niggling injuries we all pick up over the course of our lives. And you recover quicker, so any tenseness you ended up with by riding in a weird position for 5 hours will be gone the next day, and not lead to a week of funny walking.
But I do think there is a weird trend over the last years where positions got more and more upright, saddles lower and bars higher, as if everybody would want to ride their bike like a Dutch city bike.
Can’t see any conspiracy though.
The place I use does a physical assessment and takes a number of measurements and uses all that data combined with motion and pressure mapping to filter out an individual and unique position. My short torso relatively long femur, wide shoulders, good core, good flexibility, narrow stance, crooked as f pelvis, getting love handles decades of riding/racing generates a position on the bike as unique as my fingerprint.
Seems to me that a bike fit is not an exact science with only 1 outcome.
Also, there are trade-offs between Comfort and Performance.
What is meant with pro vs amateur fit is that a pro fit is aimed more towards performance than an amateur fit.
But also as an amateur when you get a bike fit, the bike fitter will first sit down with you and discuss what your goals are. So if you indicate you want to go all out for performance you can get a pro fit just as well.
