TrainerRoad Nutrition
Fuel Your
Training
Right
Get a personalized, science-based nutrition plan designed to make you faster.
Built on the Energy Availability model — the same framework used by sports dietitians to optimize fueling, protect health, and drive adaptation in endurance athletes.
Loucks et al. 2011Loucks AB, Kiens B, Wright HH. “Energy availability in athletes.” J Sports Sci. 2011;29(sup1):S7-S15. Established EA thresholds for metabolic and hormonal function in athletes. Mountjoy et al. 2018Mountjoy M, Sundgot-Borgen JK, et al. “IOC consensus statement on RED-S.” Br J Sports Med. 2018;52(11):687-697. Defined Relative Energy Deficiency in Sport and EA-based screening. Thomas et al. 2016Thomas DT, Erdman KA, Burke LM. “Position of the Academy of Nutrition and Dietetics: Nutrition and Athletic Performance.” J Acad Nutr Diet. 2016;116(3):501-528. Macronutrient and energy guidelines for endurance athletes.
Daily Nutrition Calculator
Step 1 of 5
lbs
watts
Weekly Training Schedule
Set your typical training duration and intensity for each day.
Mon
hrs
Tue
hrs
Wed
hrs
Thu
hrs
Fri
hrs
Sat
hrs
Sun
hrs
Weekly total: 0 hrs
Body Type
Which body type is closer to yours?
Body Composition
If you've had a DEXA scan or use calipers, enter your result here.
ft in
Your height is needed for the circumference estimation method.
in
Measure at the narrowest point, just below the Adam's apple.
in
Measure at your navel, standing relaxed.
in
Measure at the widest point of your hips.
Daily Activity Level
Outside of training, how active is your day? We use this to estimate the calories you burn from everyday movement — walking, standing, chores.
I know my typical daily step count
steps
If you track steps, enter your typical daily average. We'll use that instead of the tier estimate.
Daily Calorie Intake
Enter your typical intake for each day. Leave blank for days you're unsure about.
Mon
kcal
Tue
kcal
Wed
kcal
Thu
kcal
Fri
kcal
Sat
kcal
Sun
kcal
Daily average: -- kcal
No problem -- we'll calculate your target nutrition plan based on your goal without comparing to current intake.
Your Goal
Only your email is saved. Your health data stays in your browser and is not stored.
The Science
Understanding Energy Availability
What Is Energy Availability?
Energy Availability (EA) measures how much energy your body has left for basic physiological functions after accounting for exercise. It is calculated as (Energy Intake − Exercise Energy Expenditure) ÷ Fat-Free Mass, expressed in kcal/kg FFM/day. EA is considered the gold standard metric for assessing whether an athlete is fueling adequately to support both training and health.
Unlike simple calorie counting, EA accounts for your body composition and training load, giving you a far more accurate picture of your nutritional status. An optimal EA ensures your body can recover, adapt, and perform at its best.
Why EA Matters for Cyclists and Triathletes
Endurance athletes are at elevated risk for Relative Energy Deficiency in Sport (RED-S), a condition where chronically low energy availability impairs performance, recovery, and long-term health. Both male and female athletes are affected, and the consequences extend well beyond the bike -- including hormonal disruption, weakened bones, and compromised immune function.
By monitoring your energy availability, you can fuel your training as a performance optimization strategy rather than guessing at calorie targets. The goal is to find the fueling sweet spot that supports your body composition goals while keeping your EA in a range that promotes adaptation, power output, and overall well-being.
Common Questions
Frequently Asked Questions
How do I calculate my daily calorie needs for cycling?
This calculator uses an Energy Availability (EA) based approach, which is more accurate than simple TDEE (Total Daily Energy Expenditure) calculators. Instead of applying a generic activity multiplier, it accounts for your actual exercise energy expenditure and body composition to determine how many calories you need to fuel both your training and your body's essential functions.
What is a safe rate of body composition change for cyclists?
Sports science research indicates that maintaining an Energy Availability above 30 kcal/kg FFM/day is critical for preserving health and performance. Below this threshold, athletes risk hormonal disruption, impaired recovery, and decreased power output. A gradual, moderate approach -- keeping EA in the 30-40 kcal/kg FFM/day range during a deficit -- helps you optimize body composition while protecting your ability to train and adapt.
Should I eat differently on rest days vs training days?
Yes. A periodized nutrition approach adjusts your carbohydrate intake based on training load -- more carbs on hard training days to fuel performance, fewer on rest days when glycogen demands are lower. Protein and fat intake generally stay consistent across all days to support recovery, hormone production, and overall health regardless of whether you ride.
How accurate is the body composition estimator?
This calculator uses the U.S. Navy circumference method, a research-validated approach for estimating body composition. While it provides a reliable estimate for most athletes, it is not a replacement for clinical methods like DEXA scanning. For the most accurate results, take measurements consistently at the same time of day and use the estimate as a tracking tool over time rather than focusing on a single reading.
What does Energy Availability mean for my performance?
Low Energy Availability directly impacts your power output, recovery capacity, and training adaptations. When your body does not have enough energy for basic functions, it down-regulates processes like muscle repair, glycogen replenishment, and hormonal balance. Over time, this leads to decreased FTP, higher fatigue, and greater injury risk. Maintaining adequate EA is one of the most impactful things you can do to protect and improve your performance on the bike.
Get Faster with
TrainerRoad AI
TrainerRoad builds adaptive, AI-powered training plans that evolve with your fitness. Fuel smarter, train harder, and see real results — proven to make cyclists faster.
Sign Up Today
Get faster with TrainerRoad AI Start Getting Faster
