With my Garmin Vector pedals I do a zero offset prior to a work out via my Edge.
I also record my TR workouts to Edge as I’m recording to TR. (so i can see additional info Garmin provide)
Why does TR not require a Zero Offset of the pedals?
The Zero Offset is stored within the pedals, which means any app or device connected to it will use the exact same power data.
In essence, once you Zero Offset a power meter (or calibrate a trainer), that is all you need for any use in that timeframe.
Interesting. So if I never zero’d the pedals via the Garmin Edge, they wouldn’t be Zero’d via TR?
Thanks
Correct. The ZO process is about the PEDALS, not the app or device.
Obviously, we need those devices and apps to perform a ZO, but once done… that is the data shared for all connected items until the next ZO.
