XC Race Tire Thread
Saw a lot of Trinotal/Dub combos this week at Breck Epic.
Hopefully not on the side of the trail getting plugged… :rofl:
Contintental Magnotal - BRR
Wow, neck and neck with the Dub Grip at 17psi. More evidence that compound is way more important than tread when it comes to rolling resistance.
Hopefully won’t hijack thread: looking at trying some of these 2.4" tires (short list is Mezcal XC Race and 2.4" Dub) for the rear of an Epic 8. Anyone run these (or other 2.4") on your Epic 8? How was rear clearance?
No issues unless you are in crazy bad mud.
I have run the following 2.4 tires on the rear of an epic 8 with no issues (some measure bigger than 2.4):
Measure small: Dubs, Ricks, All Specialized 2.35
Measure true or bigger: Barzo, Rekon Race, Aspen, Rekon, 2.6 Barzo (close), Peyote
No problems running any 2.4 tire I’ve tried on the Epic 8 (Anything from Dubs to DHRs). I’ve never considered this would be an issue.
I have recently put on Dubnitals after glowing reviews on yt from Guy Kesteven. Dub trail Grip and Trail rapid f/b, They are 59mm on 30mm id. A bit small compared to Rekon Race of which i used last time i had xc tires on. I live in the northern part of scandinavia and have had small bouts of rain every day, all summer. Everything is wet, and there are som mud also. My home-terrain is kind of like pnw at first glance but the dirt is not as firm (am I told). Basically hiking-tracks in the forrest with and without roots, rocks and some puddles. Quite technical.
At first the dub’s where slippery. I had expected them to be, but not like this. After a while, and after adjusting pressure i found them better and after yesterdays ride I must say as Guv Kesteven did, they are far better than they look. They probably had some molding-silicon or whatever that contributed to the slippery-ness. It took some time to get used to having round front tires again opposed to the kind of squared Rekon Race. The tires do corner well, but not in the same way as the more pronounced cornering knobs of Rekon Race do. I did adjust the flipchip on the bike to get a bit steeper headtube angle and it helped to not have to lean the bike as much. I really like these tires and they do work also on wet roots. In muddy parts they just slid to wherever and I had to just come along for the ride. I also had a trip to our xc bike park and did some man-built flow trails with banked turns. Obviously they want more pressure than on singletrack, and they do not cope as well where there are rolling stones on hard surfaces.
I have heard that the dubs are to squirmy when having adequate mtb pressures, sub 20 psi, but i did not find that. Maybe the trail casing on my tires have more suppert than the race casing. I started with 18-19 psi, and let out some in the front at two times underway. When i got home i measured the front to 13, which I had already decided whas no enough air. For my next ride i plan to test 18-15, and then take it from there. I guess ill end up with 16-19. I have insert in the back.
If its dry you’ll be fine. Mud? You might get some rubbing action on the seat stays. That is my experience even with aspens which have smaller side knobs.
make Schwalbe Rocket Ron Super Race Addix Speed 29x2.35 stick to the top @BRR , crazy that a touring!!! tire got more votes this month (and almost overall) as one of the most versatile XC tire available…
honestly, what kind of psycho puts a vote on a touuuuuring tire? :sweat_smile: its heavy, its slow, its sh’t..
well a roadie might say the same about mtb tyres…
touring riders may also not want to be riding tyres any slower than they need to be for the required durability.
Has anyone ridden the Kenda Dagger tires? What are your thoughts on them?
The Daggers are on the BRR vote list, but going to fall off after this month.
The Schwalbe Rick XC Pro Addix Speed (black) 29x2.4 are also on the list and may be worth trying to push up the rankings. I am going to put my vote on them this month.
Do you have any further thoughts on your setup? I have been thinking about switching to Dub Trail Rapid 2.4 on Rear, Trinotal Trail Grip 2.4 on Front.
I have been using the newest version 2025 Specialized Fast Trak Grid Lite T5/T7 TLR in 2.35 on the Front and Rear for a season and have like that setup overall but I don’t think its a very fast rolling setup.
I have also used a Vittoria Barzo G2.0 XC Trail 2.4 Front and Mezcal G2.0 XC Trail 2.25 in rear.
The Barzo has been my favorite front tire I’ve ever used.
I’m a pretty mediocre descender skill wise and I found that the Mezcal 2.25 on the rear was not very confidence inspiring for my current skill level as a rear tire.
I am really curious how the Dub Trail Rapid in the rear will feel compared to the Mezcal, specifically does it still feel like a fast rolling rear tire but give a little more confidence.
I mostly ride and race on pretty chunky dry/loose over hard single track with some pretty sharp rocks.
Thanks
IMO almost any high performance tire will feel better than the Mezcal on sketchy descends. Vittoria xc carcass is pretty bouncy but they sure are fast.
I went from the specialized tires that came on my epic 8 to a dub rear and Tri front. The dub/Tri definitely roll faster and I’m content with them on anything BUT wet terrain. Wet rocks, roots, etc., they are pretty bad. I used them for dry/sandy terrain in Bend races successfully. After my race at the end of the month, I’ll put the specialized back on for the winter as it gets wetter.
Specialized Fast Trak Flexlite 2.35 seem to be sold out everywhere in Europe. Is there an update incoming?
Hello hive mind for XC tyres/tires:
I’m impressed by the level of knowledge and experience on this thread so I’m asking for advice as to how much of a difference it would make to my riding to switch tyres and maybe wheels.
I have a Chisel HT which I upgraded to Roval Control alloy wheels and which runs the stock Fast Trak T5 tyres. I have flat pedals with pins and good grippy shoes.
I am in my fifties and not fast - my aim for the spring is 3W/kg and my riding on this bike is more gravel than trail, I explore tarmac lanes, farm tracks, bridleways and so on and a typical ride is 15-25 miles.
I am tempted by a gravel bike for obvious reasons but as a cheaper option if I replaced the tyres on the Chisel with something like a Dubnital 50mm race rapid and maybe even got lighter wheels (for example Roval Control carbon) would I see a significant increase in speed for the same overall effort?
Obviously I’m not racing but if I can go faster I can go further and have more flexibility in planning routes. I am open to new shoes and SPD pedals as well as I am clipped in when on my road bike.
Many thanks for reading this far, feel free to spend or save my money as you see fit :folded_hands:
hi there
John Karrasch is active in this forum and in this thread. He does a lot of chung method rolling resistance testing. Check out his website with the table of tested tires on different soil here: Articles — FlexFit by John Karrasch
Another great resource is Mountain Bike Tires Test Results | Bicycle Rolling Resistance. It’s good in terms of seeing where your current tire ranks in regards to the faster one - I’d ignore the absolute values but focus on the relative difference between fast and slower tires.
If I were in your shoes I’d consider either the Pathfinder TLR 2.2 (55) or the Vittoria Peyote 2.4 depending on how much volume you think you’d want. They both roll pretty fast on Cat 1 gravel and tarmac. Both should be pretty light tires as well.
I wouldn’t buy a lighter wheelset as this doesn’t really affect your speed once your rolling. I’d focus on getting a thight fitting jersey, an aero helmet and may be look into inner bar ends for a more aerodynamic position. This will have a bigger effect on your avg speed than a 1100-1200g wheelset on your MTB.
There is research on flat pedals vs clippless pedals and there is no significant difference in mechanical efficiency. One study showed that trained cyclists were less efficient when told to pull up on the upstroke. If you have cycling shoes for clipless pedals you’re happy with I’d save my money and just keep riding them until they break apart and decide then. Clipless pedals won’t make you faster.
Get faster tires, aero helmet, thight fitting jersey and if it’s not obvious already bibs, even long bibs for the winter and keep riding consistently. That will make you much faster than any bike parts you can buy. hope that helps
For your application as I read it, I’d suggest taking a look at the new specialized pathfinder pro 55 tires.
