Trek Supercaliber Cage
Hi, I am on a 2025 Trek Supercaliber size Medium. This is my first full suspension bike and having some trouble with the bottle cages fitting. I have a side entry one for the downtube and even that is tricky with the axs flight attendant battery. Any recommendations?
Thanks,
Brandon
I don’t have a Supercailber, but what you’re describing sounds somewhat similar to my situation with a side load cage. The bottle fits but I can only put it and out by tilting it out to the side. IDK if this works in your situation, but to put it in I have to first stick the bottom of the bottle into the bottom of the cage from the side, then pivot the top inward into the cage Removing it is the opposite, first pulling the top out to the side, then extracting the bottom from the bottom of the cage. It is a bit awkward.
