@mcneese.chad interesting and many thanks! Do you see a trend with riders moving a bit more forward?
In my area, yes. I think the forward position tends to feel more powerful and gives a more commanding feel on the road, vs a more rearward position.
That said, I have had to resort to the forward position in some cases due to rider restrictions and improperly sized bikes. I often have to balance stem length and saddle position to get a reach the rider wants, but still keep the bike āsafeā in terms of steering and weight distribution. Not ideal, but I have to work with the bike and rider in front of me.
I like the KOPS to 10mm forward as well and use it on most of my bikes (road and MTB).
In general I am very interested in fitting, tend to read up many related texts online or in printed form and like to experiment with many things myself. I am quite happy with my position but there is one small thing that I could use some input on. I read somewhere ā and unfortunately donāt remember where ā that if you tend to hold your bars further back than the hoods this is a sign that you may need less reach. Vice versa if you tend to hold from the tips at the furthest end of the hoods then it is a sign that you probably need more reach.
This is a bit confusing to me because it seems to depend on the effort. When Iām cruising along easily I always hold either the tops or the bars just behind the hoods. When I am doing hard efforts be it on flat or uphill i always tend to stretch so far forward that it is just my wrists touching the tips of the hoods (which is also a bit unstable). Is such a big discrepancy to be expected? Does this possibly imply something about my reach?
I was thinking that maybe the discrepancy would be less pronounced if I raised the bars a bit (and maybe increased the reach simultaneously). However due to a cut steerer I could only raise my bars by flipping the stem and moving it under my 8mm of spacers. Leaving aside that this looks terrible, it also results in a raise by 14-15mm which is definitely too much. Any thoughts about this theory?
My take, ask yourself where you spend most of your time positioned on the bike and bars, as well as the most widely used effort relative to that position.
I consider this a type of 80/20 thing, where I want the default that you land on for most riding to be your āhomeā position, at your typical power output.
As such, I most often aim to get a rider with comfortable hold around the hoods, having the inner web of the hand (between the thumb and fore finger) resting very near or against the back curve of the hood, while doing their Tempo to Threshold effort for racer types, and Endurance for more casual riders.
I recommend this specific position (regular wrapped hand right on the hoods) as the 80% spot because you have the most control on the handlebars, ability to shift and break without moving your hands. Having to move from a gapped position as the 80% home position just seems less than ideal IMO.
When it comes to the āpowerā or ārelaxedā positions as part of the 20% use, I want to make sure they are accommodated. But they are secondary to the most often used power and positions. Most often these seem to work as a result of arm reach (via elbow bend) and/or back angle changes from the 80% position.
As to adjusting your setup, with a short steer tube:
- Assuming you are already as high as you can go with with stem spacers under a negative angle stem (6-8*?), and if you think the flipped stem version is too tall, you need a stem with less angle.
- If you have something with more angle than 6-8*, you can just pick a step down from there.
- If you have a 6-8*, you might be able to use a Specialized 4D stem with their inner angle shim to get something in between yours simple flipped.
- One trick to consider, is to simply rotate the bar angle up a bit, with the same stem setup. This does two things. It actually raises the contact points a small amount, which may be what you want. It also changes the potential wrist angle to the forearm. I end up using flat to 5* positive bar angle (as viewed from the side of a level bike) for many riders. The angle is usually higher as the saddle to bar drop decreases. But just tweak from feel to see if you like it and how much is ābestā.
Thanks a lot Chad, this makes a lot of sense and is very helpful. I would say that most of my riding is around 180-220 watts and for that range I am also tending to hold the hoods as intended
About the stem question, I use a 90mm -6* stem on top of 8mm of spacers and cannot go higher. I tried to get a 0* stem at some point but could not get any at the time (I could only find two models, one from Thomson and a Ritchey intended for MTBās. During the stock-shortage-period of COVID I could not find these anywhere on stock). However the 4D stem sounds like it could be quite useful for trying out things also in the future.
Regarding the angle up tilt, I would rather not try it since (i) it also increases the reach, and (ii) anything more than 2-3* (which is what I have) makes it harder to reach my campy thumb shifters from the dropsā¦
At long lastā¦ I broke down and got a TT bike! Lots of background on how I got here over the past year:
I went with a 2016 Cervelo P3 - itās a great fit with my existing deep wheels, and wanted something that allowed lots of front end flexibility and ease of use as I try to further work on position now that I am not constrained to also riding it as a road bike.
I tried using the PadX/PadY concept to set an initial position very similar to my final redshift/road position but with slightly more reach, slightly less stack now that I donāt have to keep a sustainable road position in mind.
Iāve only got about 3 hours on it (2 hr kitchen sink testing it out + 1 hr nonstop high Z2 the next day) and so far it feels surprisingly great. No pain anywhere at all yet.
Here are some things Iām wondering on the new bike (left) relative to old bike (right) - and maybe the pros will point out stuff I just donāt see or get!
Is my saddle too high? On the road, felt OK - if anything, I havenāt had any top of knee pain that has been a low level issue on the road bikeā¦ maybe road bike is too low?
I had S-bars with the redshift setup also angled up slightly - they look so much cooler and I never had wrist pain - so I almost want to just move them to this bike. I also added DuraAce 9071 shifters to my S-bars with buttons on top that line up with my thumbs perfectly, while these have chunky two button shifters that are slightly less natural to operate - possibly because they are too high. Is it reasonable to consider cutting down the end of the J-bar looking at how much they stick up for me? They are not bad for comfort - and if I go lower, maybe Iāll have issues with S-bars, so Iām going to keep experimenting with them
ISM says start with a 1-2 deg tilt - but not sure if that is more for road use? Should I be aiming for more tilt on a TT bike to help rotate forward? Really liked the redshift forward tilt built into the switch seatpost and wasnāt sure how much to push this one. Also, while I can fairly accurately measure pad X/Y relative to BB / ground, the saddles are so different that Iām not really sure if I have āequivalentā saddle position. Does the new bike look reasonable for setback?
My arms are not so vertical on the new bike - I guess from the slightly increased pad X and/or saddle not quite same relative setback - and the front view seems to further suggest that Iām lowerā¦ maybe flatter? I also felt that I was reaching a bit more past the armrest pad to the get to the hand grip position - initially, I thought Iād definitely bring them back closer, but after riding it, Iām not so sure. What should dictate this pad-to-grip reach? The other thing Iāve noticed is that itās a tad bit harder for me to look up the road - so rimless glasses may be on list soon. All in all, I think Iāve largely rotated down and out as I wanted to, but I donāt know how to read stuff like pelvis angle, etc. Should I be exploring pushing any further, or does this look too far in any direction, or something missing?
Iām supposed to go for a major bike fit soon but just trying to do some preliminary tweaking to get ācloseā and maybe have more specific feedback from a decent reference point that could help further inform that fit. Appreciate any input!
Left - P3 quick setup using a stem I had laying around to get close to my existing setup
Right Trek Madone H2 geometry w/Redshift that Iāve been on the past year
A few quick thoughtsā¦
your saddle on the P3 does look a little high but it is always hard to tell for sure from a static shot.
as you discovered, extending your reach actually helps lower your upper body. You donāt necessarily have to always lower your stem to get your body lower. That said, you may have a bit too much reach going on. My initial reaction is that you could move back a bitā¦but then you should also lower your stem. That would help keep your body in a similar position. Iām a big fan of having your arms NOT be verticalā¦allows you to āturtleā your head better.
One more for @mcneese.chadā¦been having annoying pain in/around the trapezius muscles. Sometimes extending up into the neck and down towards the lat level. Checked the saddle tilt and it was more nose up than I remembered/wanted/thought. So, I tilted it level maybe a touch nose down and I felt less pressure.
Question is have you seen a nose up saddle tilt cause pain like I described? Seems counterintuitive so, just checking as saddle height, reach, drop are all where theyāve been for yearsā¦
@KorbenDallas, sorry for the delay. Poor time management again
Canāt say that I have seen a direct 1:1 connection, but I would not be surprised if it would/could be related.
Anytime you have a saddle situation that leads to āinstabilityā you are likely loading muscles in ways that are not ideal. In the case of a sloping saddle, that leads to a rider having to now support themselves more, it can lead to excess or inappropriate muscle loading.
With a nose high saddle, it may be causing you to hold the bars a bit more tightly, and the traps at the top of the chain in the triangle (formed by the back and arms) would be a likely candidate for āholdingā you in place.
So I think it is very likely related to your feeling and improvement. My goal in saddle position and angle is to get the rider āstableā with foundation of support that doesnāt push or pull the rider in any particular direction. I want a neutral hip and mid section, with the upper and lower body able to do what they need without undue influence from a bad saddle setup.
This x1000ā¦too often people tilt their saddles one way or another as a crutch to fix other fit issues. āneutralā and āstableā should be the starting points of any bike fitā¦
Iāve noticed over the years a trend for my saddles to be all the way forward on their rails. This is true on both my road and cx/gravel bike. Both bikes are sized to me by using inseam and height and the saddle height over the BB is more or less identical. I like the position, have no issues with it but I canāt help feeling that it shouldnāt be like this, that I should have a different sized frame to make up for some weird anatomical feature that I donāt know I have.
Iāve set my saddles with KOPS from the start and tried out the hands on the back method, which didnāt indicate that anything was off. Anybody out there have a clue to whatās up with this? And in how should I think about frame size going forward?
@gandlf just making sure I understand where youāre coming fromā¦are you saying you need/want to go down a frame size to maybe take advantage of a stepper STA which would get you more forward over the BB?
If so, one thing I hadnāt considered until going through a similar issue with a new bike, is how the saddle rails can affect fore/aft. As much as a couple cmās in some cases. Anyways, just something to consider if you are trying to get a little more forwardā¦
Nothing specific without more info. We know you have bikes that are sized by height and inseam, and you slam the saddle forward. We also hear that you have no complaints, other than wondering if your current saddle fore-aft position may indicate something āwrongā.
With no pain or other problems, this may be much ado about nothing. Or, itās a flag that there is something off elsewhere, but youāve not given any indication of that. Short of more info and pics of you on the bike, anything here is a guess at best.
Adding to that, saddle position in the seatpost rails is one thing. But the seatpost setback is an important variable in this discussion. My guess would be that you have stock ones that are often around 10-20mm setback, but you could have one that is 0mm or even longer than 20mm. And it may well be different between your bikes.
That all ignores the seat tube angle, that may also differ between your bikes. To some degree, this can be ignored. But when people are at the limits of one or more adjustments, it raises this higher up in the review process.
You mention KOPS, so can you clarify precisely what you did for setup with respect to alignment and markers on you and the bike? This may all settle into something of a non-issue, but itās hard to say with more info.
I just went and had a look at my road bike and Iād say it has a setback of 20mm at least, the seat tube angle for that bike is 73.2. The saddle is a Selle Italia SLR. Iāll try to get some photos the next time I have an indoor ride booked. The reason Iām asking is that Iāve started to the slow process of looking for a new bike and Iām starting to question whether I should look for a smaller frame than recommended. It works well, but it looks a bit off, like the fit compensates for something.
The KOPS I did was from the spot just under the kneecap, I dropped a stiff, weighted tape measure in a line from that spot down through the pedal spindle in the 9 oāclock position. But this was years ago. Iāve never felt any knee pain.
Iāll get some photos though so you can see how it looks next time I have the bike on the trainer.
Iām thinking I might be better served by a smaller frame, but to be honest I 'm not sure why? It feels weird that a bike that should fit me well, requires me to keep the saddle all the way forward. Chad pointed out the setback, which I didnāt think about. If I would have a zero-setback seat post I think my saddle would look more normally positioned.
Iām wondering because Iām slowly getting ready to get a new bike, and I just wonder if this is a known thing that I should take into account and how to do that going forward.
For startes, can you give us your height, inseam and what size bike you are currently on?
As noted by chad, a saddleās position on a seatpost is relative to a lot of different factors.
Iāve been dealing with saddle sores for the past few months. I read at multiple places that bringing the saddle down could help so I dropped it by 5mm but now I feel like itās too low. From the pictures bellow does it look like Iām too low?
Qualifier, itās impossible to make more than a decent guess with just two pictures.
That said, it could be a tad low, but you still have a toe point (slightly elevated heel), so itās not drastically too low, if at all. I mention the toe point because dropping the heel can be one way our body compensates for a saddle that is too low.
You didnāt mention the state of saddle issue after the height change. If you were chasing a saddle comfort improvement, and the drop didnāt fix the problem, you may want to return to the prior height.
Thanks Chad. I did a quick spin and it seems to have improved the issue but I have a longer workout planned tomorrow so I will reassess and update. Appreciate your input!
