That’s essentially it. I like to try to build the ability to work hard after a hard effort, thus for me I found good workouts at doing 30s/2:00 or :45/3:00 and focusing on a somewhat harder Under rather than raising the “over” power.
At the start, a :30@110% over might not burn, but after 30 minutes of this work, it definitely does. Now, I think you could potentially scale it in the same way that coaches like KM apparently prescribe VO2max work in that you scale it back later in the workout, just going by “feel” the entire time, but with longer sustained intervals, it’s going to be a lot harder if you burn up matches at the start trying to get a certain burn, rather than just letting it build as fatigue builds throughout the duration of the workout.
So, in base, I’m looking to shuttle lactate and increase the power I can operate at while doing so (the Under) far more than I’m worried about hitting a higher power target during the over. And then I want to train how many overs/unders I can do, and then I want to spend more time over.
The issue I’ve had with TR’s O/U structure is that I think theirs spend way too much time “Over”, personally. A lot of their O/U workouts are great, but some of the later ones they prescribe just spend too much time above threshold (and usually at 105%) for what I think they’re trying to accomplish.
Kind of what I settled on last block of these was 92% - 110-113% with a 4:1 ratio of under to over time. Then adding more total TiZ. I started with a 2x20 with 2:00/:30 at 92%-110% and progressed to a 3x18 on 3:00/:45 92%-113%. These were achievable without crushing me. If I’d kept going, I would’ve gone to 3x20 and bumped the under to 94%.
If I was doing a race simulation workout, I would probably do a higher over (120-140%) and then float at a lower power like 85-88%. I do really like the “over unders” Chad calls billats in short power build, but I wouldn’t do those in Base because they’re friggin’ hard.
All MO, I’m not coaching anyone, so do what you think is best or what works for you.
