Strava Segment File
Is there an easy way to export a file with elevation and distance for all your Strava Segments?
It seems that you can only download a GPX file of a route, so that would be a very tedious process for 20-30 segments.
Appreciate any ideas from the forum.
I’m using the Elevate extension for Chrome on Windows and am able to ‘Export GPS segment effort’ when I locate a segment in a ride, under the regular Strava button to Analyze, Set Goal, Compare and Improve your time 2 more orange buttons appear to export the segment effort’ and show extended statistics of effort.
You’d need to use it once per segment still, but it exports just the segment so no further cropping to do
Thanks a lot, will try your solution this weekend
So I ended up using Veloviewer, bcs It’s close to what I wanted to do with the segments comparison.
