I’ve currently got a “standard” SRAM AXS force powermeter crankset (not wide version) and I’m wondering if the AXS powermeter spider can be used with the wide setup. I know I won’t be able to use the smaller bolt pattern for the 94 bcd 43/30 rings, but hopefully it works with the 107 BCD rings. I understand that the spindle is wider on the wide version, but I’m not clear if there are other differences that could make the power meter spider incompatible. It seems that sram has married up the wide with the smaller bolt pattern, but I think I read somewhere that you can run the larger rings in the wide config. If that’s true, it would have to use the larger spider and my hope is the powermeter spider is fair game. Any guidance is appreciated.
Zombie thread…. Yes, the Quarq spider PM fits the Wide spindle crank (with normal 33/46 rings). The width is all in the spindle (with spacers outboard the BB).
