Reaching out to an SL7 owners to see if they have experienced this issue and if so how to fix it?
The top part (the plastic bit before spcaers) which goes overs the headset seems to be rubbing on the frame causing friction and hence no a smooth movement for the bars. Its rubbed the paint away a little too.
Pre load on the headset seems ok and not too tight, any looser and it’d knock. Any ideas?
