Should my rest weeks be set to dynamic endurance days?
i do roughly 6 hours of training a week. typically 3 hard indoor sessions and one outdoor endurance solo ride on the weekends.
I have a rest week coming up which is set by default as 1 hour monday, 1 hour wednesday, 1:30 friday and 1:15 saturday total of 4:45
but if i change them all to dynamic endurance with the highest upper limit (so set to 5 hours) it makes monday 1:45, wednesday 1:30, friday 3:00 and saturday 4:30 total of 10:45. Seems a good amount above my normal volume? for reference, TR has never told me to do a 4:30 endurance ride before. it then triggers a red day for sunday
If i flick back between the two options above, the volume changes, can show down to 8 hours. Seems all over the show
should i try it or set back to original?
I’m not a huge fan of TR’s recovery week structure in general, but specific to your question, you should not increaae your volume randomly by almost 80% on a rest week.
Let’s derail the thread. :blush: How do you prefer your rest weeks to look?
Well … depending on where your hard rides fall in you loading weeks, you can end up with 11 or 12 days without any intensity if you have none at all in your rest week.
That can make for a bit of a shock to the system when it comes around.
its just interesting that TR suggests this. is this a bug?
It depends on what the preceding training block was, but usually 2-3 full days off the bike, a short workout with some efforts to wake up the system, then back to the grind.
Dynamic Endurance rides are not by setup/design/intent to be an everyday thing use case (or '“test” in your case), also that programming likely isn’t setup to handle the rest week in your case. I know for my regularly scheduled Sunday Dynamic Endurance (<5hr typically unless i know i don’t have the time/energy). On recovery week it seems hard coded to go to 45minutes only. It also is a new feature sort of and isn’t fully baked IMO.
You should be riding easy plenty during that week and shedding fatigue. Recent updates to TR with AI have added much higher % of FTP in the past (high zone2 instead of true ‘easy’ low zone2). Also the lack of any intensity does seem weird, from a running training back ground… you typically do some work, just much less (similar to tapering). For most people towards the end of the week you are feeling fairly fresh (unless on a high volume plan)… leading into a hard week of new workouts… can easily feel very flat/tired…feeling ‘untrained and unready’ for such hard efforts. Seems to me some short opener type workout would be smart on Saturday or Sunday (considering monday is probably easy or rest also)
You should Definity keep it back to original with minor adjustments on one or two of the rides to suit your needs/preferences (like maybe extra 30min to the saturday ride cuz you want to enjoy fall weather) or a sunday spin out of legs with some very short hardstart sweetspot intervals or something. or an openner workout w/longer warmup
I am 100% with you… just curious how you structure your recovery weeks.
There was a good thread on recovery weeks here: What does your recovery week look like?
I am all for a reduction of volume and intensity, but as you mentioned, as prescribed the “week” has potential to be pretty long between high intensity days. Personally I like taking the weekdays easy with something in the middle like unstructured segment hunting for fun. Then by the weekend I am ready to get back to it.
It depends on what I’ve been doing, but I’ll have a chill start to the week and then probably do a Zwift race or spicy group ride on Thursday or Friday.
I agree with some of the others that it’s not common to use Dynamic Endurance this way (every single day of a recovery week).
I wonder if you’re running into a bug that’s giving you that output. :thinking:
What happens if you change an endurance ride to a Dynamic Endurance on a regular basis(non-recovery) week?
I set to dynamic endurance for the week just to see what would happen, i had assume the AI model would deal with the volume appropriately but possibly not in this case.
my setup is usually 3 indoor intervals monday wednesday friday and then saturday is set to dynamic endurance solo rides. my saturday rides fluctuate around the 2 hour mark. it seems when i accept an ftp change that the saturday rides drop in duration. my only explanation for this is the model is assuming with the same IF (say 0.65) that there is a decent jump in effort. so if i kept the same FTP then the duration would keep getting longer with the same IF, but with the jump, it thinks i need to reduce the duration to stop the training load to be too high.
My calendar is below if you want to view
