Hi, I created a plan using planbuilder towards a multi day event. I played with it last week, adding, removing workouts to see the impact on ftp. Now my event is in 3 weeks and I want to reset the plan so that I get the optimal tapering towards the event. It may delete all my changes in the future but I don’t want to change anything I’ve done in the past.
There’s probably other ways to rebuild the plan but if I add a new event it resets planbuilder.
Did you manually add individual workouts, or did you change your schedule in Plan Builder?
If you manually added workouts, you can just delete them.
If you changed your schedule in Plan Builder, just go back into the edit schedule step and select whatever is recommended for you.
Let me know if this helps!
I added, removed and changed workouts. I first tried updating the schedule this indeed made the ai replan workouts, however it seemed to completely plan over the goal multi day event. Then I added the event again in the hope the plan would adjust. Nothing happened but now I had twice the same event. I removed one event (maybe the wrong one) and now when clicking on the plan it said xx weeks and 0 events. Then I deleted all events, edit the existing plan, go all steps back all the way to the first question and selected the target was an event. I specified the event, set the start date in the past, updated the schedule et voila everything seems to be fine.
I do have one question: it is supposed to taper to A events, right? It seems to do so but I was expecting a much more aggressive taper. The hours / week are very close to the average. I think I will remove the last high intensity workout two days before the race. It will be my travel way anyways and it might be hard to train on that day.
