So I had to wipe and reboot the old laptop (MS Surface Pro 3) I use to run Zwift (TR is done via iPad and BT). That happened in November and it worked fine after the reboot.
But with the most recent Zwift update, I can’t get Zwift to run…i get a message saying the .NET framework is preventing it from running.
The exact message is:
BLOCKING ISSUES:
The .NET framework 4.7.2 is not supported on this operating system
I have no problem running Zwift on my current work laptop, both of which are running Windows10 as the operating system.
Anyone run into this issue or have any suggestions on how to fix it?
Hasn’t Zwift turned off older OS computers, as in Zwift will no longer work? I have no idea how old or new a Surface 3 is but as I understood it anything Win 8 or lower was a goner…
As I read the error message I am getting, it seems that I need to REMOVE 4.7.2, not install it? It says my OS does not support it, but I can’t find where to uninstall it (not listed in the Apps / Programs section in Settings)
This laptop has always run Windows 10.
I think the Os is current on updates, but will double check. I just had to basically reinstall it after it crashed in November.
