I stopped doing pettite… It ALWAYS messed up my HR… always higher that it should…
N=1
I’ve done my share of JD as well. Can’t say that I remember much about it, though.
mines pretty reliable. Sure there is a lag, and sure it might vary a few bpm, and I can move the needle by changing position on the bike or not drinking enough water, but otherwise its pretty reliable.
Mine is mostly good on running. In cycling…not so much…
Not trying to push an end game or push for an alteration. Just you said I should not make assumptions, that was the only point. I pointed out TR is power based so to conclude people are here using power was quite safe and not an assumption.
Might I suggest spending a little more and stepping up to Wild Turkey Rare Breed? $0.02.
Just a thought… doesn’t the workout text sometimes mention HR, especially when you’re working on cadence?
Like I said before, HR is a factor.
I’d maintain it’s an internal factor rather than an external one (200w is always 200w, whereas 150bpm can be a reflection of a dozen or more things), but it’s a factor.
Has anyone actually nay-sayed that?
I would counter that HR is an indicator rather than a factor…
It may indicate you are tired or you didn’t rest, or dehydrated, or many other things…
But to me, I have never use it as a factor, other than decide if I need to slow down during the recovery days…
Not saying that is not an important metric to keep an eye tho
I don’t think we’re disagreeing, we’re just using language slightly differently.
As I noted earlier in the thread, I just use it to check nothing is ‘off’, especially if it’s all feeling a bit of a slog (or unusually easy).
I’m just trying to work out exactly what the argument is here?
There is no argument put forth. The OP put forth an emperor has no clothes type of discovery.
I do sometimes I stopped tracking HR two years ago or so. I monitor it for running only, I will check HR on endurance race efforts I suppose.
More broadly I think there are three kinds of users;
- Training is a secondary activity to riding: just use power, get it done, move on.
- Long time indoor trainers: track power, HR, volume and TSS
- Statos: everything from HRV to blood oxygenation and it’s all important
I started off as a 3 and a novice to exercise, probably now a 2 but struggling to become a 1 and finally free!
I use HR quite a bit in running and riding. I have found over time certain HR levels that I can predict blow up time. When in a group ride for example, if i get to about 168 to 170, I know i have to back off, doesnt matter the heat/codl/coffee no coffee - I ave about 5 minutes left. I then bring it back down about 10 bpms for a rest and can go again. Same in running - about same bpm too. I now have a Powermeter and is interesting to now learn this correlation.
I’m guessing that’s going to be LT2 HR?
Very likely. I can tell just by feel when I am at that point. I just did Spencer +2 today and like clockwork about 1 min in was getting to that HR and knew I can make it to the end of the interval (2 more mins), but if i was asked to continue, wouldn’t happen.
Funnily I specifically said I’m not saying power is the Emporer’s new clothes
