Going hard up alpe du zwift I’m at about 95% or max HR most of the way. 185 average for the climb and my max hr is 196.
I think I could probably go a bit harder too and be holding closer to 190bpm. Average power was 249 but think I could have held 260 at the time.
As it’s almost an hour long (54 minutes), I’m assuming this is around my threshold hr. But this seems way off suggested zone 4 HR percentages. Eg some say zone 4 tops out at 80% mhr.
I’m pretty sure my max is my max - hit 195 or 196 in ramps tests or on 3 minutes climbs where I really give it everything.
I can’t hit my max HR in ramp test. Without looking at my stats I think I hit about 93% of it. I wouldn’t get too worried about hr however (unless doctors have told you otherwise) and use power.
At the end of a 20mins test or a TT in the past Ive hit 100% but in the last 4 months the most I’ve hit is 99% (and averaging what I max for in a ramp).
The power vs HR chart in Intervals.icu is good for this question (shameless plug!). So for me approx 89% max HR is threshold. And I haven’t managed to get as fit as I was last year
D) I suck at ramp tests perhaps. I get better motivation/output on a longer test. I don’t feel I am under trained (perhaps the opposite since I joined TR, I think harder but sub hour turbo sessions suit my 45yo body batter). My equipment seems to be giving me consistent information too as are external results. I think I am just one of the bell curve outliers, roll on adaptive training
In Lamarack, my intervals at threshold were 156, 162, 165, 167 bpm, which is 85.7%, 89.0%, 90.7%, 91.8% of max hr (182).
My max hr in that workout was 173, which is 95.1% of max hr.
Relative to past levels of fitness, I am currently on the untrained side. When trained, I would have been closer to 87%.
The only place I have ever hit max hr is during a ramp test. Never seen it anywhere else. Those last two minutes are brutally hard and it often does take me quite a while to recover.
Threshold HR (LTHR) as % of Max HR varies wildly. FWIW my LTHR is 92%.
The Coggan and Friel heart rate zones are based on LTHR. In the Training and Racing with a Power Meter book, Coggan notes they are merely guidelines due to individual differences (even when referenced to LTHR).
Last time I hit my max HR I nearly blacked out. You REALLY don’t want to hit your max. You will definitely know when you have when you fall off your bike.
I’ve hit 99% a few times and been ok. I haven’t hit 100% for a while, not that I really want to, as you say it’ll be on the edge of nearly blacking out and crashing
Or the ramp test is leg limited rather than heart limited.
When I took time off for the off season, my first ramp test I hit max hr. I’ve come within 2 bpm since… once (zwift race) and apart from that I’ve not even hit 97%… even doing vo2 work
Also for reference, 1 hour hr is 174bpm, max is 190 (so 92% threshold hr)
