New Shimano RX710 gravel shoes (and Assioma pedal pods)
I just got a pair of Shimano RX710 gravel shoes. Shimano advertises using a new last for these shoes with a more natural foot shape and more toe box volume. They’re also available in narrow and wide widths. I got W and they fit me very well, way better than anything else I’ve tried over the past few years. My feet have gotten wider as I got older and I have arthritis in my toes and these are working very well for me.
Among other features, they include an integral replaceable pontoon system for a better pedaling platform with their pedals. A side benefit for me is they nicely clear the pods on my older Assioma power pedals. I like everything about these shoes wrt fit, materials, construction, BOA setup and operation, appearance… They are categorized as gravel shoes but I see nothing about them that would not work equally well for mtb. I’ll be using these on gravel and XC mtb.
I purchased the RX910 last year, which were the “new” Shimano gravel shoes introducing the pontoon system. I liked them so much, I soon bought the similar MTB style which is nearly the same but better cleats and no pontoon.
I can tell a decent difference between them in support, but also in clipping in. The pontoons feel WAY better planted, but are noticeably harder to clip in.
As you mentioned, the pontoons work just fine for XC as well. I’d say that for any really steep/technical, and shorter rides, I prefer the MTB version for ease of clipping in when it’s really steep. However, anything that’s longer, (3-4+ hrs) or just a bit less technical in general, I’m always reaching for the pontoon “gravel” shoes.
Does your model have the two holes to drain water? I thought it seemed a little gimmicky (not sure why), but then I had multiple water crossings in a 100 mile XCM race and those drain holes were heavenly. I worked the pontoon models for the XCM race in lieu of the mtb ones. Oddly, the mtb ones don’t have the holes. I’ve thought about drilling them? lol.
Lastly, I’m envious of the new width. Mine are wide, but I either would be better off with a half width larger or the new wider model. I love them, but they can get tight over time. At $700 for the two pairs, I don’t think I’ll be replacing them yet…
Shimano’s RX line never fit like their XC or RC lines, imagine my surprise when I’ve been in 10 years of Shimano shoes and all of a sudden the RX800 forefoot crushed my feet, even with wides.
Sounds like they’re moving everything back in-line with the rest of the lineup? Or is this a totally new last altogether?
I’ve got little time on the new shoes but did notice the resistance of the pontoons on the pedals when clipping in on Shimano XTR pedals, and I could feel it moving my heal in and out within the float. I’m assuming once the pontoons wear a little it will go away. If not, grinding them down a smidge where they hit the pedal will likely do the trick. Being replaceable, there’s not much risk.
As far as holes in the soles, these have a hole in the toe and one at the heal. The uppers have a a good amount of perforations and no membrane afaik, so def not water resistant.
IDK, I’m not a Shimano shoe aficionado, but as I understand it, these are based on a whole new last design. The toe is much more rounded than previous designs. I do have a pair of 13 year old R170 road shoes that I still wear on occasion. These are 1/2 size up and still fit me well, but of course they’re well broken in. Other than that I’ve had a few pair of Shimano flat pedal shoes, but that’s a whole 'nother thing.
Another trick I have seen mentioned is to add a shim under the cleat. I have not tried that, though.
Doesn’t that defeat the whole design to stay “better connected with the pontoons” though?
I dug in a little more to the fit, apparently it’s Dynalast 2.0, which only exists on the RC910, RC810, and RX710 so far. RX910 is on the original Dynalast. :distorted_face:
I did more riding paying particular attention to clipping in on XTR pedals. I also looked in more detail on how the cleats/pontoons interface with the pedal. At this point, I don’t think it’s the friction between the pontoon and pedal. The pontoons aren’t in contact with the pedal when the front of the cleat is hooked in until the rear of cleat is latched. Even then, the friction is minimal, at least on my shoes and pedals. What I think is going on is if the cleat isn’t lined up left/right with the pedal, the pontoon hits the top pedal and hinders finding the center of the pedal. Also, if I put my toe on the pedal first, the big lugs forward and on either side of the pontoons hit the pedal and prevent my foot from sliding forward. I def need to study this more.
After a bunch of rides and looking at how clipping was working, I came up with a minor mod to the pontoons that’s made it way easier for me. The pontoons hug the cleat very closely wrapping around the sides and if I wasn’t exactly lined up left and right with the pedal, the front edge of a pontoon would hang up on the pedal preventing clipping in. I chamfered the inner edges of the front of the pontoon and that has done the trick for me. Here are a couple of not great pix.
Thanks for the pic’s, I am thinking of getting a pair of these, I have been riding the MX5 shoes and had to modify the lugs, much like this, I even cut out the side a bit as they were longer/deeper than the cleat and they would squeak where the rubber touched.
