So like many others I’m having issues with my Snap. Resistance too high etc. my guess so far is that it doesn’t calibrate properly for temperature.
But one question I still have… what’s y’all offset number when you calibrate? Mine is usually something like 40210. Yep 40 THOUSAND. Is it a normal reading? Maybe it doesn’t have room to calibrate because it’s already at max offset?
I’m having the same problem. Had an old bike on the Wahoo Snap. Put a mountain bike on the trainer that has a power meter on it. Power difference between the power2max power meter and the snap varied from 0 to 40 with the snap always showing less power. Also, I got an offset number of 1286. I was thinking that the offset was the difference in readings between the two power meters. Can someone please clarify what the offset reflects? I REALLY need to feel that my indoor power numbers are the same as my outdoor power numbers. As I mostly use TR plans outdoors.
