I completed Summa Ri training session a while ago.
As it reads in its description “Summa Ri consists of a total of 13 power ramps ranging from 133-150% FTP.”
During the course of the training session, it became evident that not all ramps are counted towards the total effort. In other words, during the ramps marked red in the picture below
the white dot between “Power” and “Target” does not appear. The first ramp is not accounted for, after the end of the fourth ramp there is a 17+ minutes time interval that extends until the end of the eighth ramp and the last ramp is not accounted for as well.
Is it a coding/programming problem of this specific training session?
Shout out at @ZackeryWeimer for the above, just for a “heads up”.
To your question: on the main training screen, on the upper left corner, there is a field called “Power” and a field called “Target”. When there is an interval in play, a white dot appears between the two fields and our goal is to match “Power” with “Target”.
In the picture in my initial post, I have circled the intervals where the white dot should be appearing and it doesn’t.
In case the above is not clear enough, I’ll post a video of the problem.
The reason why this is happening has to do with how the rest level is set for the workout.
Intervals that have any section under the rest interval will not be considered for the intervals table on the Ride Analysis Page, so they won’t prompt an in-ride Interval Summary once its completed, and the white power ball won’t appear either. However, the good news is that all ramps are counted towards the total effort, they are just not appearing on the Intervals Summary.
We’ve fixed this problem for Summa Ri workout, so if you complete the fixed version in the future the missing ramps should show on the Interval Summary.
Thank you very much! Next time I’ll do the Summa Ri workout, I’ll report back, here.
Furthermore, now that you found the problem with the Summa Ri workout, I would kindly recommend you to have a look at all similar workouts, i.e. Keeler Neddle, Keeler Needle -4, Stone, Scaraben and Nied. I am 90% sure that Keeler Needle and Keeler Needle -4 are facing the same issue with Summa Ri and since the other three follow a similar motif, they probably face the same issue as well.
