Oopsie
I’m using virtual power, i know i should get a power meter.
But as long as you keep everything the same, it may not be accurate, but at least repeatable.
I had this happen to me before, but figured it would not happen again.
I used my trainer this year again and had it at resistance setting 3. But due to cable tension being too slack, the resistance was probably at level 4 or somewhere between 4 and 5.
Which means when think you do a certain resistance, you are really doing quite a bit more.
