@Helvellyn The harder choices the AI gives me are almost always way too hard. Like a full PL or more, and almost always “not recommended.” On occasion I’ve gone through the library manually and found a suitable substitute (roughly 0.5 - 1.0 PL harder, same type of intervals) and completed them as expected - the higher end of moderate to hard.
@MikeMunson I’ve been doing this long enough (15-ish years), and am old enough (57) that progression is challenging to discern in the space of one or 2 blocks. I figure my FTP is somewhere between 314 and 320, but definitely higher than the 302 it thinks I’m at, and nowhere near the 330 it was predicting a while ago. That said, I’m pretty sure I could be progressing faster.
@eddie I’m doing structured workouts as directed by the plan - typically 1 VO2, 1 Threshold each week, plus 2 easy days, and an endurance day. Those are planned, but unstructured, but I’m pretty good about sticking to the intended effort levels, with deviations for unavoidable terrain requirements. I also have a Monday group ride which varies from mildly challenging to drooling on my stem for 90 minutes. In the event of stem drooling, I usually either skip or take Tuesday’s easy day really easy. Prior to regenerating my plan about a month ago, I was doing nearly everything as TR workouts, and prior to the weather getting nice, I was doing everything inside. I always ride with a power meter and HRM. The robot should be drowning in good data.
As for workout alternates, I touched on that above. Generally the AI suggestions are useless. Below is what it gives me for alternates to Whiteleaf (scheduled for next Sat). Whiteleaf +1 is barely harder (3 TSS and 0.01 IF) and Lion Rock isn’t quite the same, but would be harder because of the longer intervals. However, ALL of its suggestions are “Not Recommended.” If they’re really not recommended, why is it even suggesting these? And why are they not recommended? The first two are only marginally more difficult than Whiteleaf, and while the others are more challenging, I doubt I’d fail any of them, though Villebois might be tough. It seems the threshold for “Not Recommended” is a very low % chance to fail, as whiteleaf +1 has only a 3.3% chance. That’s insignificant. Villebois has 11.8% - that’s worth a “Not Recommended” label.
I took a look at the workout library, and there are 21 hard start threshold workouts between 2.3 and 3.2, inclusive. I would think it would pick from those.
Oh, and I just remembered that I have my plan set to ‘demanding.’ It doesn’t feel demanding.
I’ll probably bump my FTP a touch and see what happens. One thing I would like to be able to do is block the AI from changing my future workouts without my express consent, and a preview of what it’s going to do before I give it the OK. Seeing the twinkling AI stars on every future workout after completing every workout is irritating at the moment. Sometimes nothing changes, sometimes it does, and sometimes I can’t tell because I don’t remember what it started as. And the FTP prediction/detection debacle does not inspire confidence at this point.
Sorry for the rant.
-Tim.
