Hi,
WKO5 build 550 now has a separate sports type for indoor cycling. However, it does not currently detect TrainerRoad rides synced via TrainingPeaks automatically as indoor rides.
I’m not sure if this can only be implemented in TrainingPeaks side? I guess it depends on how the sync API between TrainerRoad and TrainingPeaks is implemented, as the rides seem to be synced in TCX format, which does not support tags (as FIT does), afaik? But the solution to this would be to get ‘CyclingIndoor’ tag automatically added to activities synced to TP from TR (currently, only ‘Cycling’ tag gets added).
So could this additional tag be implemented in TrainerRoad side? If not, could you help in making this happen in TP side?
Br,
-Mikko
