Hey folks,
happy to be here …quite an uncommon use case but I was hoping that maybe some of you have the same. Maybe also a good question for @GPLama as you tested the CABLE converter as well as the faveros
Ok, here we go:
I was hoping to transmit the IAV Cycling Dynamics data from the Favero DUO to the Polar V650. Knowing that those data are being broadcast via Ant+ (and that the Polar V650 only supports bluetooth) I purchased the CABLE Ant+/Bluetooth Converter. The CABLE converter was able to recognize the Faveros Ant+ data and transform these into bluetooth. So far so good. I was also able to pair the CABLE converter with my Polar V650. But it does not show the IAV Cycling Dynamics data.
I suspect it won’t work as ANT+ Cycling Dynamics has no equivalent Bluetooth Smart profile to use… so the CABLE has nothing to map it to from ANT+ to BLE. Ultimately one for NPE support to confirm/clarify.
Thank you @GPLama …just sent out a request to NPE. Will let you know what the outcome is.
However, I suspect you are right saying that there is no such BLE smart profile - which is a pitty because that use case would make many people happy as there are still many bike computers out there only supporting BLE.
