Hello. I am not a avid cyclist , not what so ever. Purchased smart bike to get in shape. Am 56, and 30 pounds over the top. Tried the ftp accessment and did not make it more than 7 mins. Am wayyy out of shape apparently.
I put therefore manually an ftp of 50? Any reccomendations on what training program to start at? And what ftp it should be? Am not looking to do triathlons in the future, just to get and keep in shape.
Thankyou
I would do 1-2 weeks of the âEnduranceâ rides and then re-test. If youâre been sedentary for a long time you likely just need to wake your system up and youâll do much better.
First of all, welcome to the forums.
Secondly. you didnât fail the assessment. You took it and you now have a baseline to improve from.
Build a plan in plan builder, follow it as best you can, eat good food, and youâll get better over time.
My biggest piece of advice is to only compare your results to yourself. There are some very strong riders on this forum and it can be a bit discouraging to read about their FTPâs and power numbers. I know this disappointment myself as I have a relatively low FTP.
But comparison is the thief of joy. Being consistent in my training and diet and comparing my journey to my own goals makes it all OK. When I start looking at my FTP versus other peopleâs FTP makes me cranky and riding bikes is supposed to be fun.
So keep it all in perspective and have fun - youâll get there!
Agreed with earlier comment.
Just get on the bike and maybe start off with shorter session workouts such as âDansâ just to get used to pedalling constantly for 30 minutes.
Then build up time to 1 hour with something equally steady like âLazy Mountainâ. Then you can graduate to âPettitâ which is also 1-hour but at a slightly higher level.
After a couple of weeks you should have a good feel for it and then can explore some of the other workouts and at that point see if you feel ok to try the ramp test again. If not then leave it a little longer, there is no pressure to rush the process.
Donât be in any rush to accelerate your intensity or duration, particularly if you are starting from a completely exercise free (recent years) background.
Your fitness will come over time
Best of luck and make sure you focus on enjoying the process rather than just setting goals at this stage
Was not expecting such quick responsesđ Thankyou, I will give reccomendations a go.
