Hi all
Does anyone have this riser block, and could you tell me the actual height measurements of the lowest and highest settings?
Many thanks
Hi all
Many thanks
Hi @onemanpeloton, I had a look at the spec linked on the page itself and found the following:
TECHNICAL DATA·
Diameter: 74 mm·
Minimum height: 350 x 120 x 100 mm·
Maximum Height: 350 x 120 x 155 mm·
Weight: 700 g
So I guess 100mm to 155mm is what you’re looking for?
Wow, can’t see the wood for the trees!
Thanks
