Calibration device question
Something I’m a bit confused about… (sorry if this has been asked before!)
When you perform a spindown (I’m using Kickr Core) can you use any device to do it? Or is the result of the spindown only communicated to the software you are using?
For example I use my phone to perform the spindown on the Wahoo app as I find the TrainerRoad spindown on PC a bit buggy, but when I’m actually using the trainer I’m using TR on the PC.
I guess I assumed that a calibration would set something on the hardware itself, but now questioning myself. :thinking:
Thanks!
  • The spindown calibration can be done on any compatible device/app. The results get stored in the trainer for that point forward, for use in any other device/app.
So, do the calibration with whatever works easiest for you.
Brilliant, thanks.
